Discarding Trim Waste (Inner Booklet Trimmer-A1)
Follow the procedure described in this section to discard trim waste from the Inner Booklet Trimmer-A1 that is installed in the optional Booklet Finisher-X1.
1
Open the front cover of the finisher.
2
Pull out the trim waste tray.
Hold the trim waste tray handle and gently pull it toward you.
Pull it out completely, supporting it with your hand.
3
Discard the trim waste.
4
Return the trim waste tray to its original position.
Make sure to insert the trim waste tray as far as it will go.
5
Close the front cover of the finisher.
