Other Finishing Functions
Depending on the installed options, you can use other finishing functions. Optional Equipment
Rotate 90 Degrees
You can output each set of paper in alternating portrait and landscape orientation.
Hole Punch
You can make punch holes for filing.
Z-Fold
You can fold the right half of the paper into three sections.
C-Fold
You can divide the paper into three sections so that it folds in the shape of a C.
Half Fold
You can fold each sheet of paper in half.
Accordion Z-Fold
You can divide the paper into three sections so that it folds in the shape of a Z.
Saddle Fold
Using the booklet finisher, you can fold the output sheets in half. You can specify how many sheets to fold together and which page to start printing on.
Double Parallel Fold
You can fold the paper in half and then in half once more.
Depending on the paper type, you cannot use finishing functions. Specifications
13X7-048
