If the System Manager ID and PIN of the client machine are different from that of the host machine, the device information cannot be distributed. Changing the System Manager ID and PIN
It may take several minutes to prepare for the device information distribution process, or to update the information after it is received. Do not turn OFF the machine until the preparation or update process is complete. Doing so may cause the machine to malfunction.
The setting update screen is displayed on the client machine that receives the device information, and no operations can be performed until the update is complete. It is recommended that you distribute the device information at a time when there are no users.
Distribution and update of device informationThe device information may not be distributed or updated when the client machine is processing other data.
If a client machine is unable to receive the automatically distributed device information at the specified time, distribution is not performed again until the next specified time.
Receiving device information from different Canon multifunction printer modelsWhen the machine is used as a client machine, it can receive device information from different Canon multifunction printer models by setting <Restrict Receiving Device Information> in <Receiving Settings> to <Off>. Note, however, that some of the information may not be distributed correctly.
Selecting the functions to receive device information forWhen the machine is used as a client machine, you can restrict the functions to receive information for by setting <Restrict Receiving for Each Function> in <Receiving Settings> to <Off>.
Restoring the previous device informationYou can perform operations on the client machine to restore the device information that existed before the update was performed. However, you can only restore the information that existed immediately prior to the update. Information older than that cannot be restored. Note also that the settings for <URL Send Settings> in <Set/Register Confidential Fax Inboxes> (<Set/Register Confidential Fax Inboxes>) may be erased if the data for <Settings/Regist. Value> and <Address Book> are not restored at the same time. <Device Management>
