Specifying Paper Size and Type in the Paper Deck/Drawer
1
Load the paper in the paper deck/drawer.
Loading Paper in the Paper Deck/Drawer
2
Press
3
Press <Preferences>
<Paper Settings>
<Paper Settings>.
4
Check the paper size that is displayed.
When loading standard size paper, the paper size is automatically detected.
(paper deck 1, on the right),
(paper deck2, on the left),
(top paper drawer),
(bottom paper drawer).
Depending on the options installed, the display differs.
NOTE:
If the displayed paper size is different from the loaded paper size, the paper may not be loaded properly. Load the paper again.
If <Custom> is displayed even though the standard size paper is loaded, press <Custom Size>
<Cancel Settings>. The correct size will be displayed.
When loading custom size paper
0UUY-023 0X7F-02A 0X6E-02A 0X7C-02A 0WXY-02A 0WR6-02A 0WR5-02A 0UW1-023 0X7H-02A 0X6W-02A 0X7A-02A 0X7E-02A 0WR7-02A 0WR8-02A
Specify the paper size loaded in the paper drawer.
1
Select the paper drawer in which paper is loaded and press <Custom Size>.
2
Specify the length of the <X> (shorter) side and <Y> (longer) side.
Press <X> or <Y> to enter the length of each side using the numeric keys.
NOTE:
3
Press <OK>.
5
Select the paper source in which paper is loaded and press <Set>.
6
Select the paper type and press <OK>.
NOTE:
If the paper type loaded is not displayed, press <Detailed Settings> to select from a list.
7
Press <OK>.
8
Change the paper size label of the paper drawer as necessary.
Attach the paper size label at the same height as the cassette number indicator, and approximately 1/4" (5 mm) to the left.
* Approximately 5 mm
LINKS
