1
Press <Standard Size>.
2
Select the paper size and press <OK>.
1
Press <Custom Size>.
2
Specify the length of the <X> (shorter) side and <Y> (longer) side.
Press <X> or <Y> to enter the length of each side using the numeric keys.
NOTE:
If you register the paper size you use frequently on buttons <S1> to <S5>, you can call them up with a simple press. Registering Free Size Paper (Custom Size Paper)
3
Press <OK>.
If a screen other than that for specifying the paper size and type is displayedIf a message prompting you to adjust the paper guide is displayed, adjust the width of the paper guide again and press <OK>.
