Replacing the Staple Cartridge in the Stapler Unit (Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO)
Follow the procedure described in this section to replace the staple cartridge in the stapler unit for the optional Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO.
1
Open the front cover of the finisher.
2
Pull out the staple case from the stapler unit.
Pull it out by holding the green lever.
3
Remove the empty staple cartridge from the staple case.
4
Take out a new staple cartridge from the box.
IMPORTANT:
Remove the seal that holds the staples together after you place the staple cartridge into the staple case.
5
Insert the new staple cartridge.
6
Hold the green lever, and push the staple case back into the stapler unit until it is securely in place.
7
Close the front cover of the finisher.
13X7-0HA
