When a Service Call Message Appears
When a malfunction occurs and the machine does not operate normally, a message may appear prompting you to contact your local authorized Canon dealer. Solutions vary depending on what additional message or button is displayed.
0UUY-0XS 0WR6-0JU 0WR5-0JU 0UW1-0Y4 0WR7-0JU 0WR5-0JU
Solutions may include a restart operation. The print data waiting to be processed will be deleted by turning OFF the machine.
If the machine does not operate normally or the same message is displayed again even after restarting, the problem may be associated with the main unit. Turn OFF the machine, unplug the power cord, and contact your local authorized Canon dealer.
When the <Turn the main power OFF and ON (using the switch on the right side of the main unit).> message is displayed
A temporary problem may have occurred. The problem may be resolved by restarting the machine, as described in the procedure below.
1
2
Confirm that the Main Power indicator is off, and wait at least 10 seconds.
3
When the <Limited Functions Mode> button is displayed
When the <Turn the main power OFF and ON (using the switch on the right side of the main unit).> message is displayed, the <Limited Functions Mode> button may also be displayed. This button enables you to switch to the Limited Functions Mode, which restricts some of the functions, allowing you to use the machine even before the problems are resolved. Switch to the Limited Functions Mode by following the procedure below.
1
Press <Limited Functions Mode>
<Yes>.
2
3
4
The machine starts in the Limited Functions Mode.
When the <This function is currently unavailable.> message is displayed
The function you selected is not available. Press
to return to the Main Menu.
When a message is displayed prompting you to contact your local authorized Canon dealer at the bottom of the display
You can use some of the functions even before the problems are resolved. The available functions are listed below.
Functions available when the print function is restricted:
0UUY-0XS 0X7F-0JK 0X6E-0JK 0X7C-0JK 0WXY-0JL 0WR6-0JU 0WR5-0JU
Fax, Scan, Remote Scanner, Web Access, Tutorial, MEAP Applications, Quick Menu, Status Monitor/Cancel, Remote UI
Functions available when the scan function is restricted:
Access Stored Files, Fax/I-Fax Inbox, Print, Hold, Web Access, Tutorial, MEAP Application, Quick Menu, Status Monitor/Cancel, Remote UI
You cannot perform some operations of the available functions, if the operations are associated with the restricted functions.
