When SNMP management software is usable, you can set, monitor, and control the machine through a computer. For details, see your software's instruction manuals.
1
Press <On> in <Use SNMPv1>.
If you don't use SNMPv1, press <Off>.
2
Press <Set Dedicated Community>, <Set Community Name 1> or <Set Community Name 2>.
The exclusive community is a community (group) prepared for managers using Canon software such as imageWARE Enterprise Management Console. To use the exclusive community, press <Set Dedicated Community>. To specify a general community, press <Set Community Name 1> or <Set Community Name 2>.
3
Set the community.
![]() ![]() To use the selected community, press <On>. When you don't want to use the community, press <Off>.
![]() For each community, select MIB access privileges from <Read/Write> or <Read Only>.
![]() Enter a community name that you belong to using alphanumeric characters. If you select <Set Dedicated Community>, you cannot set an exclusive community name.
4
Press <OK>.
1
Press <On> in <Use SNMPv3>.
If you don't use SNMPv3, press <Off>.
2
Press <Administrator Settings>.
3
Specify the necessary settings, and press <OK>.
![]() ![]() If you use Administrator, set to <On>.
![]() If you use a password which is different from the authentication, deselect <Use Same Password as for Authentication>, press <Encryption Password>, and enter the password.
4
Press <User Settings>
5
Enter the necessary information.
![]() ![]() Enter a user name using alphanumeric characters.
![]() Select MIB access privileges from <Read/Write> or <Read Only>.
![]() Set a combination of authentication and encoding. Select <Auth. Yes/Encrypt. Yes>, <Auth. Yes/Encrypt. No>, or <Auth. No/Encrypt. No>.
![]() Select <MD5> or <SHA1> according to your environment.
![]() Enter a password to use for authentication. When the password is entered, <Confirm> is displayed for confirmation. Enter the password again.
![]() Select <DES> or <AES> according to your environment.
![]() Enter a password to use for encoding. When the password is entered, <Confirm> is displayed for confirmation. Enter the password again.
6
Press <OK>
7
Press <Context Settings>
8
Enter a context name and press <OK>.
9
Press <OK>.
When using SNMPv1 and SNMPv3 in combination, it is recommended to set MIB access privileges for SNMPv1 to <Read Only>. If you set <Read/Write>, almost all of the machine's operations become practicable and the strong security functions of SNMPv3 will not be effective. Access privileges to MIB can be set in either SNMPv1 or SNMPv3. In SNMPv3, you can set them for each user.
If Administrator is disabled, you cannot specify settings in <SNMP Settings>
