Staple Finisher-V1
Paper Size/Weight/Type
Size
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTR, LTRR, EXEC, STMTR, and Custom Size/Free Size (4" x 5 7/8" to 13" x 19 1/4" (100 x 148 mm to 330.2 x 487.7 mm))
Weight
14 lb bond to 140 lb index (52 to 256 g/m2)
Type*
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, and Coated
* Coated paper can be loaded from the insertion unit only.
The Eco (Staple-Free) mode cannot be used for heavy paper, transparencies, tracing paper, labels, tab paper, bond paper, letterhead, or coated paper.
You cannot staple transparencies, tracing paper, or labels.
Capacity Per Tray
(Tray A)
No Collating/Collate/Group
LTR, EXEC, and STMTR: 250 sheets (or 1 7/8" (47 mm) in height)
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTRR: 125 sheets (or 1" (24 mm) in height)
Offset mode (Collate/Group)
LTR and EXEC: 250 sheets (or 7/8" (47 mm) in height)
11" x 17" and LTRR: 125 sheets (or 1" (24 mm) in height)
Capacity Per Tray
(Tray B)
Capacity Per Tray
(Tray C)
LTR, EXEC, and STMTR: 3,000 sheets (or 16 5/8" (423 mm) in height)*1
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, and LTRR: 1,500 sheets (or 8 1/2" (216 mm) in height)
No Collating/Collate/Group mode with different paper sizes
LTR and EXEC: 3,000 sheets (or 16 5/8" (423 mm) in height)*1
Corner Stapling and Double Stapling
LTR and EXEC: 200 sets (or 16 5/8" (423 mm) in height), or total 3,000 sheets*2
11" x 17", LGL, and LTRR: 100 sets (or 8 1/2" (216 mm) in height), or total 1,500 sheets
Staple-Free (Eco)
11" x 17" and LTR: 200 sets
*1 Thin (14 to 15 lb bond (52 to 59 g/m2)): 1,500 sheets (or 8 1/2" (216 mm) in height)
*2 Thin (14 to 15 lb bond (52-59 g/m2)): 100 sets (or 8 1/2" (216 mm) in height), or total 1,500 sheets
Max. Stapling Capacity/Available Staple Size*
LTR and EXEC: 65 sheets (24 lb bond (90 g/m2))
11" x 17", LGL, and LTRR: 30 sheets (24 lb bond (90 g/m2))
Staple-Free (Eco)
11" x 17" and LTR:
5 sheets (14 to 17 lb bond (52 to 64 g/m2))
4 sheets (17.3 to 21.7 lb bond (65 to 81.4 g/m2))
3 sheets (21.7 to 28 lb bond (81.5 to 105 g/m2))
Manual Staple
* When the standard staple cartridge is attached. (The maximum stapling capacity may vary, depending on the paper type and weight.)
Power Source/Maximum Power Consumption
From the main unit/176 W or less (including the Puncher Unit)
Dimensions
(W x D x H)
20 5/8" x 24 1/2" x 43 1/4" (525 x 623 x 1,099 mm)
When the auxiliary tray is extended
24 3/4" x 24 1/2" x 45 3/4" (627 x 623 x 1,163 mm)
Weight
Approximately 77.2 lb (35 kg)
Installation Space Including the Main Unit
(W x D)*1
Without the upright control panel
68 3/4"*2 x 30 5/8" (1,745 x 779 mm)
With the upright control panel
83 1/4"*3 x 30 3/8" (2,113 x 770 mm)
*1 When the auxiliary tray is extended.
*2 When the right cover of the main unit is opened.
*3 To the right edge of the upright control panel in the rightmost position.
13X7-0LH
