Paper Size/Weight/Type
Size
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTR, LTRR, EXEC, and Custom Size (7 1/8" x 7 1/8" to 13" x 19 1/4" (182 mm x 182 mm to 330.2 mm x 487.7 mm))
Weight
14 lb bond to 140 lb index (52 to 256 g/m2)
Type
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Pre-Punched, Tracing, Tab, Bond, Letterhead, and Coated (29 lb bond to 140 lb index (106 to 256 g/m2))
Paper Deck Capacity
Upper/Lower Tray
200 sheets (20 lb bond (80 g/m2)) x 2
Power Source
AC 100 - 240 V, 50/60 Hz, 1.0 A
Maximum Power Consumption
120 W maximum
Dimensions
(W x D x H)
29 3/8" x 31 1/4" x 55 3/8" (746 x 793 x 1,407 mm)
Weight
Approximately 134.5 lb (61 kg)
Installation Space Including the Main Unit
(W x D)*1
Without the upright control panel
99 1/4"*2 x 32 1/2" (2,519 x 826 mm)
With the upright control panel
113 5/8"*3 x 32 1/8" (2,887 x 817 mm)
*1 When the Booklet Finisher-W1 PRO is attached, and the auxiliary tray is extended.
*2 When the right cover of the main unit is opened.
*3 To the right edge of the upright control panel in the rightmost position.
