You can set to forward received documents to specified destinations. Fax numbers as well as e-mail addresses and shared folders in computers can be specified as forwarding destinations.
To forward documents automatically, some settings such as forwarding destinations and file formats of documents need to be specified beforehand. <Forwarding Settings>
<Function Settings>
<Receive/Forward>
<Common Settings>
<Forwarding Settings>.
If you have added lines, you can also specify a particular line. In this case, select <Fax: Line 1>, etc. for <Receive Method>.
If the selected destination is a group address which contains a Mail Box, the received document will not be forwarded to (and stored in) that Mail Box.
You cannot specify a WebDAV server as an I-fax forwarding destination.
If you specify a destination for which <Confirm Before Sending> is enabled as a forwarding destination, the screen to enter the password does not appear. The registered password is used and forwarding is performed. Registering Destinations
Selecting <Forward without Conditions> enables you to forward all received documents that do not meet the specified conditions to the desired destination.
You can forward to multiple destinations by specifying a group destination in <Forwarding Destination>.
