User's Guide | |
Paper Size/Weight/Type
Size
LTR
Weight
14 lb bond to 140 lb index (52 to 256 g/m2)
Type
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Pre-Punched, Bond, and Letterhead
Paper Deck Capacity
3,500 sheets (20 lb bond (80 g/m2))
Power Source/Maximum Power Consumption
From the main unit/Approximately 44 W
Dimensions
(W x D x H)
14 1/4" x 24 7/8" x 22 1/2" (363 x 630 x 572 mm)
Weight
Approximately 75.0 lb (34 kg)
Installation Space Including the Main Unit
(W x D)*1
Without the upright control panel
63 7/8" x 30 5/8" (1,622 x 779 mm)
With the upright control panel
83 1/4"*2 x 30 3/8" (2,113 x 770 mm)
*1 When the Booklet Finisher-V1 is attached, and the auxiliary tray is extended.
*2 To the right edge of the upright control panel in the rightmost position.
