Maximum Number of Files for Hold Queue
2,000 files (30,000 pages)
Operating Modes
Auto, PS, PCL, XPS, Imaging, and PDF
Resident Fonts
PCL:93 Scalable fonts, 2 OCR fonts, and Andale Font*1 (Japanese, Korean, Simplified Chinese, and Traditional Chinese)
PS:136 Scalable fonts
When using the Direct Print (for PDF/XPS):Japanese Fonts:
2 Heisei fonts*2 (Heisei Mincho W3/Heisei Kaku Gothic W5)
European Fonts:
136 fonts*2
*1 The optional PCL International Font Set needs to be activated to use Andale® and WorldType® Collection, or Andale Mono WT.
*2 These fonts are included for use with PDF files.
Printable Area
PCL5e and PCL6:Reduced to 3/16" (4.2 mm) from the top, bottom, left, and right edges of the paper.
PostScript 3:Reduced to 3/16" (4 mm) from the top, bottom, left, and right edges of the paper.
When printing in the Expand Print Region and Print mode, the upper margin becomes 1/8" (2.5 mm), the lower margin becomes 1/8" (2.5 mm), and the side margins both become 1/8" (2.5 mm). The printable area is enlarged.
When an original has data that extends all the way to the edges, even if you select [Expand Print Region and Print], the periphery of the data may be cut off when printing. In this case, specify the reduction ratio in the printer driver so that data is not cut off, and perform printing again.
File format
When using the Direct PrintPDF, PS/EPS, TIFF/JPEG, XPS
