Name
Canon imageRUNNER ADVANCE 8505i/8595i/8585i
Type
Reader-Printer Separated, Console type
Resolution for Reading
600 x 600 dpi
Resolution for Writing
1,200 x 1,200 dpi
Number of Tones
256
Available Paper
See "Available Paper".
Acceptable Originals
Sheet, book, and three dimensional objects (up to 4.4 lb (2 kg))
Warm-Up Time*
After Powering ON
60 seconds or less
The time until key operations can be performed on the touch panel display is 34 seconds or less. Even if <Quick Startup Settings for Main Power> is set to <On>, the machine does not startup quickly, depending on the situations.
Returning from the Sleep mode
1 minute or less
Returning from the Energy Saver mode
Approximately 20 seconds
* Activation time may vary, depending on the environment and conditions under which the machine is being used. (At a room temperature of 68°F in all above cases.)
First Copy Time*
2.7 seconds or less
Copy Speed
(sheet/minute)*
imageRUNNER ADVANCE 8505i13" x 19": 47
12 5/8" x 17 11/16": 50
12" x 18": 50
11" x 17": 53
LGL: 64
LTR: 105
LTRR: 81
EXEC: 105
STMTR: 105
imageRUNNER ADVANCE 8595i13" x 19": 43
12 5/8" x 17 11/16": 46
12" x 18": 45
11" x 17": 49
LGL: 60
LTR: 95
LTRR: 73
EXEC: 95
STMTR: 95
imageRUNNER ADVANCE 8585i13" x 19": 38
12 5/8" x 17 11/16": 41
12" x 18": 40
11" x 17": 43
LGL: 57
LTR: 85
LTRR: 67
EXEC: 85
STMTR: 85
* 1:1, except when paper is fed from the Multi-Purpose Tray. Printing performance may not be optimal, depending on the original content and combination of settings. To give priority to the copy speed, select <Text> for <Original Type>.
Margin
Top: 1/8" (2.5 mm)
Left and Right: 1/8" (2.5 mm)
Bottom: 1/8" (2.5 mm)
Magnification
Regular paper sizeSame Ratio
Direct
Reduction
1:0.78 (LGL → LTR)
1:0.73 (11" x 17" → LGL, 11" x 15" → LTR)
1:0.64 (11" x 17" → LTR)
1:0.50 (11" x 17" → STMT)
1:0.25
Enlargement
1:1.21 (LGL → 11" x 17")
1:1.29 (LTR → 11" x 17")
1:2.00 (STMT → 11" x 17")
1:4.00
Copy Ratio:25 to 400% (in 1% increment)
Paper Feeding System/Capacity
Paper decks:1, 2 (Left/Right)
1,500 sheets x 2 paper decks (20 lb bond (80 g/m2))
1,700 sheets x 2 paper decks (17 lb bond (64 g/m2))
Paper Drawer 1, 2
550 sheets x 2 cassettes (20 lb bond (80 g/m2))
680 sheets x 2 cassettes (17 lb bond (64 g/m2))
Multi-Purpose Tray
100 sheets (20 lb bond (80 g/m2))
100 sheets (17 lb bond (64 g/m2))
Multiple Copies
9,999 sheets
Memory Capacity
3 GB
Hard Disk Capacity*
250 GB or more (Used space: 250 GB)
* The hard disk capacity is subject to change in future release.
Power Source
120 - 127 V AC, 60 Hz, 16 A
Power Consumption*
Maximum Power Consumption
2.1 kW or less
When the machine is in the Sleep mode
0.9 W or less
When the main power switch is turned OFF
When <Quick Startup Settings for Main Power> is set to <Off>: 0.3 W
When <Quick Startup Settings for Main Power> is set to <On>: 0.45 W * Depending on the system and conditions of use, these values may differ.
Dimensions
(W x D x H)
Without the upright control panel
26 3/8" x 30 5/8" x 48" (670 x 779 x 1,220 mm)
With the upright control panel
58 3/8"*1 x 30 3/8" x 49 1/4"*2 (1,481 x 770 x 1,252 mm)
*1 To the right edge of the upright control panel in the rightmost position.
*2 To the top of the upright control panel in the standard position.
Weight*
Approximately 520.3 lb (236 kg)
Approximately 529.1 lb (240 kg)
* Including the toner bottle.
Installation Space
(W x D)*1
68 3/4"*2 x 30 5/8" (1,745 x 779 mm)
83 1/4"*3 x 30 3/8" (2,113 x 770 mm)
*1 When the Booklet Finisher-V1 is attached, and the auxiliary tray is extended.
*2 When the right cover of the main unit is opened.
*3 To the right edge of the upright control panel in the rightmost position.
