Make sure that the paper size setting of the paper deck matches the size of the paper to load in the paper deck.
Load the paper stack with the print side face down, and against the side wall of the paper deck.
When changing the paper size and typeIf you load a different type of paper into the machine, make sure to change the settings. If you do not change the settings, the machine cannot print properly. Specifying Paper Size and Type in the Paper Deck/Drawer
When changing the paper size, change the paper size label as necessary.
You can load tab paper into the paper drawer. Loading Tab Paper
While pressing the top part of the left guide, slide it to align with the size indicator for the paper to be loaded.
While pressing the top part of the front guide, slide it to align with the size indicator for the paper to be loaded.
Make sure that the paper size setting of the paper drawer matches the size of the paper to load in the paper drawer.
Load the paper stack with the print side face down, and against the side wall of the paper drawer.
