Network Environment
13X7-0R4
Wired LAN Specifications
Network Interface
10Base-T/100Base-TX/1000Base-T (RJ-45)
Protocol Supported
TCP/IP
Frame type: Ethernet II
Print applications: LPD/Raw/IPP/IPPS/FTP/WSD/AirPrint/Mopria
AppleTalk
Frame type: Ethernet SNAP
Print application: PAP (Printer Access Protocol)
Wireless LAN Specifications
Standard
IEEE 802.11g, IEEE 802.11b, IEEE 802.11n
Transmission Scheme
DS-SS System, OFDM System, Half Duplex
Frequency Range
2,412 to 2,462 GHz
Communication Mode
Infrastructure Mode
Access Point Mode
Security
Infrastructure Mode
128 (104)/64 (40) bit WEP
WPA-PSK (TKIP/AES-CCMP)
WPA2-PSK (TKIP/AES-CCMP)
Access Point Mode
WPA2-PSK (AES-CCMP)
Connection Method
WPS (Wi-Fi Protected Setup), Manual setup
imageRUNNER ADVANCE 8505i / 8595i / 8585i
User's Guide
USRMA-0034-012016-05Copyright CANON INC. 2016
