<Adjust Image Quality>
This section describes how to adjust image quality for copying and printing.
<Auto Adjust Gradation>
<Adjustment/Maintenance>
If the brightness of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
Adjusting Gradation
It is recommended that you select <Full Adjust> when performing an automatic gradation adjustment. Select <Quick Adjust> for a quick, but less complete adjustment between regular full adjustment recalibrations.
Only plain paper can be used for printing test pages with this machine. You cannot select a paper source loaded with paper other than plain.
Test pages are not counted as part of the copy or print total page counts.
<Correct Density>
If the density of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
Adjusting Print Density
<Fine Adjust Zoom>
If the size of the image copied is significantly different from the original document, fine adjustment is performed so that the printing more closely matches the size of the original document.
Adjusting Image Size
