2/3 Hole Puncher Unit-A1
Paper Size/Weight/Type
Size
Two Holes: 11" x 17", LGL, LTR, LTRR, and EXEC
Three Holes: 11" x 17", LTR, and EXEC
Weight
14 lb bond to 140 lb index (52 to 256 g/m2)
Type
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Tab, Bond, Letterhead, and Coated
Punch Hole Quantity, Hole Diameter
Two or Three Holes: 3/8" (8 mm)
Distance between Punch Holes
Two Holes: 2 3/4" (70 mm)
Three Holes: 4 1/4" (108 mm)
Punch Waste Tray Capacity*
Two Holes: Approximately 10,000 sheets (18.1 lb bond (68 g/m2))
Three Holes: Approximately 3,000 sheets (20 lb bond (75 g/m2))
* The figure may differ, depending on the surrounding environment, paper type, and paper weight.
13X7-0LU
