Loading Paper
You can load the paper into the paper deck/drawer or multi-purpose tray. Load the paper you usually use into the paper deck/drawer. Use the multi-purpose tray when you temporarily use a size or type of paper that is not loaded in the paper deck/drawer. For more information about available paper types and sizes, see Specifications. To obtain the optimum printing results, make sure to correctly specify the size and type of paper that is loaded. Specifying Paper Size and Type
Loading paper while stock remains may cause a multiple sheet feed or a paper jam. If there is paper remaining, it is recommended that you wait until all of it has been used before loading more paper.
Do not load different sizes or types of paper together.
Do not use the following types of paper:
Wrinkled or creased paper
Curled or rolled paper
Torn paper
Damp paper
Very thin paper
Paper printed by a thermal transfer printer
Highly textured paper
Glossy paper
Paper handling and storage
Store the paper on a flat surface.
Keep the paper wrapped in its original package to protect the paper from moisture or dryness.
Do not store the paper in such a way that may cause it to curl or fold.
Do not store the paper vertically or stack too much paper.
Do not store the paper in direct sunlight, or in a place subject to high humidity, dryness, or drastic changes in temperature or humidity.
When printing on paper that has absorbed moisture
Steam may emit from the paper output area, or water droplets may form on the back side of the control panel or around the paper output area. There is nothing unusual about any of these occurrences, which occur when the heat generated from fixing toner on the paper causes moisture in the paper to evaporate (most likely to occur at low room temperatures).
13X7-024
