To use the fax functionThe optional product is required for faxing. System Options
Configure the setting according to the fax option.You can edit the line name that is displayed in the line selection screen using <Edit Line Name for Select Line Screen>. <Send>
![]() You can change the display of the address list according to the selected line in <Default Address List When Selecting Line>. <Send>
![]() You can set to display a destination's phone number on the screen or report in <Set Number Display>. <Receive/Forward>
![]() You can set to automatically switch of the incoming fax and incoming call in <Select RX Mode>. <Receive/Forward>
