Discarding Trim Waste (Booklet Trimmer-D1)
Follow the procedure described in this section to discard trim waste from the optional Booklet Trimmer-D1.
1
Open the front cover of the Booklet Trimmer-D1.
2
Pull out the trim waste tray.
Hold the trim waste tray handle and gently pull it toward you.
Pull it out completely, supporting it with your hand.
3
Discard the trim waste.
4
Return the trim waste tray to its original position.
Make sure to insert the trim waste tray as far as it will go.
5
Close the front cover of the Booklet Trimmer-D1.
