Specifying IP Addresses in Firewall Settings
You can set whether to allow or reject communication with a device that has a specific IP address. After configuring the IP addresses in the firewall settings, you can check the results in the log of blocked communication requests. You can also set whether to allow or reject ICMP communications such as PING commands, etc., after specifying firewall settings.
1
Press .
2
Press <Preferences>  <Network>  <Firewall Settings>.
3
Press <IPv4 Address Filter> or <IPv6 Address Filter>.
Select the filter setting that corresponds to the IP address set on the machine.
4
Select <Outbound Filter> or <Inbound Filter>.
To restrict data sent from the machine to a computer, select <Outbound Filter>.
To restrict data received from a computer, select <Inbound Filter>.
To restrict data communication but allow only ICMP communications such as PING commands, etc., set <Always Allow Sending/Receiving Using ICMP> to <On>.
5
Set <Use Filter> to <On>, select <Default Policy>, then press <Register>.
For <Default Policy>, select <Reject> to only allow communication with devices that have an IP address specified in <Exception Addresses> in the next step, or select <Allow> to reject communication with them.
If <Reject> is selected for <Default Policy>, the restrictions do not apply to sending to multicast or broadcast addresses.
6
Set the exception addresses.
When using IPv4
When using IPv6
Specify the IP addresses to designate as exceptions of the <Default Policy> option selected in the previous step. Select one of the input methods described below.
<Single Address>
Enter an individual IP address to designate as an exception. In the case of IPv6, press <Address> to display the input screen.
<Address Range>
Specify a range of IP addresses. Enter a separate address for <First Address> and <Last Address>. It is not possible to enter IPv6 addresses.
<Specify Prefix>
Specify a range of IP addresses using a prefix (network address). Enter a network address for <Address>, and specify the network address length in <Prefix Length>.
Setting exception addresses for the outbound filter
1
Select the IP address input method, and enter the exception addresses.
2
Press <OK>.
Setting exception addresses for the inbound filter
1
2
Press <Next>.
3
Set the port number if necessary, and press <OK>.
Select whether to specify a port number. You can configure detailed communication restrictions by specifying a port number for the exception address.
<Do Not Specify>
The exception address setting applies to all communication received from the specified IP address.
<Specify>
The exception address setting only applies to communication received from the specified IP address using the designated port number. Press <Add>, enter the port number, and press <OK>.
To edit an exception address
On the screen displayed in step 5, select the exception address that you want to edit, and press <Edit> to display the edit screen.
7
Press <OK>.
8
Press     <Apply Set. Changes>  <Yes>.
Checking the blocked communication requests in the log
To display a log of communication requests blocked by the firewall, press   <Preferences>  <Network>  <Firewall Settings>  <IP Address Block Log>. The log of blocked communication requests can be exported from the Remote UI in CSV file format. Exporting a Log as a File
13X7-0AR
