TIPS
If you install the "Puncher Unit-BF1" in the "Staple Finisher-X1" or "Booklet Finisher-X1," you can punch holes in your printouts.
If you install the "Inner Booklet Trimmer-A1" in the "Booklet Finisher-X1," you can cut the bound output paper to align the edge of the paper.
Booklet Finisher-X1
Staple Finisher-X1
Output Tray A
Front cover
Booklet tray (Booklet Finisher-X1 only)
Output Tray C
Output Tray B|
If the booklet tray guide is not properly adjusted to the paper size, it may cause a paper jam.
Booklet Finisher-X1
Staple Finisher-X1
Staple waste tray
Punch waste tray (Puncher Unit-BF1)
Saddle stitcher unit (Booklet Finisher-X1 only)
Trim waste tray (Inner Booklet Trimmer-A1, Booklet Finisher-X1 only)|
For information on the paper sizes that can be used for Staple, Saddle Stitch, Hole Punch, and Saddle Fold, see Specifications.
To replace the staple cartridge of the stapler unit or saddle stitcher unit, see Replacing the Staple Cartridge.
For how to clear a paper jam or a staple jam, see Clearing Paper Jams Clearing Staple Jams.
The maximum number of bindable sheets may not be possible, depending on the paper type. In this case, change the paper type, or reduce the number of sheets to bind.
Collate and groupIf you select <Offset> in combination with the collate or group function, each printout group is shifted.
The output trays move downward as the output paper stacks accumulate. Once an output tray has reached its stacking limit, subsequent prints are automatically delivered to the next available tray. If all of the available trays have reached their stacking limits, printing stops. Remove all of the output paper from the trays to resume printing.
StaplersWhen you are using the Staple mode, do not remove the stack of paper from the output tray during the job. Remove the stack of paper when the job has been completed.
If the <Load staples into the stapler unit.> message appears, almost all of the staples have been used. To proceed, replace the staple cartridge.
If a tray reaches the lowest position limit, printing stops temporarily. Remove all of the output paper from the tray to resume printing.
Saddle stitchThe accuracy of folds may vary depending on the paper type and the number of sheets.
