Adjusting Paper Alignment
You can adjust the paper alignment when outputting paper to the finisher tray if you are using the optional Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO.
1
Press
<Adjustment/Maintenance>
<Adjust Action>
<Finisher Tray A Alignment Adjustment> or <Finisher Tray B Alignment Adjustment>.
If you want to adjust the paper output position when using staples, select <Alignment Adjustment When Stapling>.
2
Adjust the paper output position.
3
Press <OK>.
LINKS
