Do not place your hand in the part of the tray where stapling is performed (near the rollers) if a finisher is attached, as this may result in personal injury.
![]() Do not place your fingers or hands on the finisher when the finisher is in use. Doing so may result in personal injury or damage to the finisher.
When removing paper from the tray of the finisher, do not place your hands on the output tray of the finisher. The tray may move upward and your hands may get caught.
![]() When disposing the staple waste, be careful not to touch the staple waste, as this may result in personal injury.
The trays of the finisher move during copying or printing. Do not place anything under the trays, as doing so may damage the trays.
Do not place anything other than output paper in the trays of the finisher, as doing so may damage the trays.
Do not set/remove the hard disk holder when the machine is performing operations. Doing so may cause damage to the hard disk.
To set/remove the hard disk holder, first eliminate the static from your body. Also, do not touch the connector.
A hard disk is fragile equipment. Note that Canon will not be liable for any damages resulting from the loss of data on the hard disk drive.
