Paper Size/Weight/Type
Size
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTR, LTRR, EXEC, STMTR, and Custom Size/Free Size (4" x 5 7/8" to 13" x 19 1/4" (100 x 148 mm to 330.2 x 487.7 mm))
Weight
14 lb bond to 140 lb index (52 to 256 g/m2)
Type*
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Tab, Bond, Letterhead, and Coated
* Coated paper can be loaded from the insertion unit only.
You cannot staple transparencies, tracing paper, or labels.
Capacity Per Tray
(Tray A)
No Collating/Collate/Group/Offset mode1,000 sheets (or 5 3/4" (147 mm) in height)
Z-Fold mode (when the Paper Folding Unit-J1 is attached)30 sheets or 10 sheets/1 set
Half Fold mode (when the Paper Folding Unit-J1 is attached)50 sheets
Capacity Per Tray
(Tray B)
No Collating/Collate/Group/Offset modeIf the High Volume Stack Mode is set to 'Off':
LTR and EXEC: 2,000 sheets (or 11 1/4" (285 mm) in height)
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, and LTRR: 1,000 sheets (or 5 3/4" (147 mm) in height)
If the High Volume Stack Mode is set to 'On':
(The maximum stack volume may vary, depending on the paper type.)
LTR and EXEC: 4,000 sheets (or 19 1/4" (490 mm) in height)
LTRR: 2,000 sheets (or 11 1/4" (285 mm) in height)
11" x 17" and LGL: 1,500 sheets (or 8 1/2" (216 mm) in height)
13" x 19", 12 5/8" x 17 11/16", 12" x 18": 1,000 sheets (or 5 3/4" (147 mm) in height)
Staple modeLTR and EXEC: 3,000 sheets/200 sets (or 16 5/8" (423 mm) in height)
LTRR: 2,000 sheets/200 sets (or 11 1/4" (285 mm) in height)
11" x 17" and LGL: 1,500 sheets/200 sets (or 8 1/2" (216 mm) in height)
Max. Stapling Capacity/Available Staple Size*
Corner Stapling and Double StaplingLTR and EXEC: 100 sheets (20 lb bond (80 g/m2)) or below 1/2" (11 mm) in height (including 2 cover sheets up to 140 lb index (256 g/m2))
11" × 17", LGL, and LTRR: 50 sheets (20 lb bond (80 g/m2)) or below 1/4" (5.5 mm) in height (including 2 cover sheets up to 140 lb index (256 g/m2))
* When the standard staple cartridge is attached. (The maximum stapling capacity may vary, depending on the paper type and weight.)
Max. Saddle Stitch Capacity/Available Saddle Stitch Size*
Saddle Stitch25 sheets (52 to 20 lb bond (80 g/m2)) (including 1 cover sheet up to 140 lb index (256 g/m2))
Saddle Folding5 sheets (110 lb index (209 g/m2))
Size13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTRR, and Custom Size (8 1/4" x 11" to 13" x 19 1/4"(210 x 279.4 mm to 330.2 x 487.7 mm))
Cover WeightRequires the paper weight of the main document or more.
* Available Saddle Stitch capacity may vary, depending on the paper type and weight.
Power Source/Maximum Power Consumption
120 - 127 V AC, 50/60 Hz, 8 A/500 W or less
Dimensions
(W x D x H)
31 1/2" x 31 1/4" x 48 3/4" (800 x 792 x 1,239 mm)
Weight
Approximately 401.2 lb (182 kg)
Installation Space Including the Main Unit
(W x D)*1
Without the upright control panel
85 3/4"*2 x 32 1/4" (2,178 x 819 mm)
With the upright control panel
100 1/4"*3 x 31 7/8" (2,546 x 810 mm)
*1 When the auxiliary tray is extended.
*2 When the right cover of the main unit is opened.
*3 To the right edge of the upright control panel in the rightmost position.
