Setting Up a Connection by Specifying Detailed Settings
If you want to specify the security settings in detail or cannot establish the wireless connection using the other procedures, manually enter all the required information for the wireless LAN connection. Before specifying detailed settings, check the required information, including the SSID, network key, and wireless security protocols. Checking the SSID and Network Key
1
Press .
2
Press <Preferences>  <Network>  <Wireless LAN>  <Wireless LAN Settings>  <Other (Set Manually)>.
3
Press <Enter Manually>.
4
Press <SSID>, and enter the SSID that you have checked.
5
Specify the security settings in <Security Settings>.
Using WEP
1
Press <WEP>.
2
Select an authentication method.
To use the WEP key as a password, press <Shared Key>.
If you press <Open System>, the machine experiences an authentication is set on the wireless router. If this happens, the machine automatically changes the setting to <Shared Key> and retries the connection.
3
Select the WEP key that you want to edit.
Press any of <WEP Key 1> to <WEP Key 4>.
4
Enter the network key that you have checked.
5
Select the WEP key to use.
6
Press <OK>.
Using WPA-PSK or WPA2-PSK
1
Press <WPA/WPA2-PSK>.
2
Select an encryption method.
To set the machine to automatically select AES-CCMP or TKIP to match the setting of the wireless router, press <Auto>.
3
Press <PSK>, and enter the network key that you have checked.
4
Press <OK>.
6
Press <OK>.
 When the wireless LAN router is detected and the configuration is complete, the screen <Connected.> will be displayed.
13X7-00H
