Staple Jams in the Stapler Unit (Staple Finisher-X1/Booklet Finisher-X1)
Follow the procedure described in this section to clear the staple jam. The Staple Finisher-X1/Booklet Finisher-X1 are optional.
Optional Equipment
1
Remove the paper waiting to be stapled from the delivery tray.
2
Open the front cover of the finisher.
3
Pull out the staple case from the stapler unit.
Hold the green lever of the staple case, and pull it out straight toward you.
4
Push up the bracket on the staple case.
5
Remove all the jammed and protruding staples from the staple case.
6
Return the bracket on the staple case to its original position.
7
Hold the green lever, and push the staple case back into the stapler unit until it is securely in place.
8
Close the front cover of the finisher.
