Using device information distribution, you can distribute Distributing the Device Information to Other Canon Multifunction Printers, import, and export Importing/Exporting All Settings settings to other Canon multifunction printers. For more information, see Settings/Registration Table.
Setting Items
Description
<Entry Tone>
Sound produced each time a key on the control panel or a button on the touch panel display is pressed
<Invalid Entry Tone>
Sound produced when an invalid key/button operation is performed, or when you enter a number outside the valid setting range
<Restock Supplies Tone>
Sound produced when the amount of toner is low
<Forgot Original Tone>
Sound produced if documents remain on the platen glass after operation is finished
<Error Tone>
Sound produced when a malfunction such as paper jam or operational error occurs
<Job Done Tone>
Sound produced when an operation such as copying or scanning is complete
<Energy Saver/Sleep Tone>
Sound produced when the machine enters sleep mode
<Login Tone>
Sound produced when login is successful
