Staple Jams in the Stapler Unit (Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO)
Follow the procedure described in this section to clear the staple jam. The Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO are optional.
Optional Equipment
1
Remove the paper waiting to be stapled from the delivery tray.
2
Wait several seconds until the stapler unit stops moving.
Make sure that the stapler unit stops moving, and then proceed to the next step.
3
Open the front cover of the finisher.
4
Pull out the staple case from the stapler unit.
Pull it out by holding the green lever.
5
Push up the bracket on the staple case.
6
Remove all the jammed and protruding staples from the staple case.
7
Return the bracket on the staple case to its original position.
8
Hold the green lever, and push the staple case back into the stapler unit until it is securely in place.
9
Close the front cover of the finisher.
