Connecting with Mobile Devices
13X7-09C
There are two methods to connect the mobile devices with the machine, "Connection by wireless LAN" and "Direct connection." Select a connection method in accordance with the communication environment and the device you are using.
Perform communication with mobile devices from <Mobile Portal> in the Main Menu. You can confirm the information of connected mobile devices, etc., from here.
Connecting with Wireless LAN
Just as connecting a computer to the machine, connect a mobile device to the machine via a wireless LAN router. Connecting to a Wireless LAN
Connecting Directly
Directly connect a mobile device to the machine wirelessly without using wireless LAN. It is possible to immediately connect to the machine wirelessly even outside of a wireless LAN environment. Connecting Directly (Access Point Mode)
If you perform a direct connection, you cannot use a wireless LAN via a router.
imageRUNNER ADVANCE 8505i / 8595i / 8585i
User's Guide
USRMA-0034-012016-05Copyright CANON INC. 2016
