Inner Booklet Trimmer-A1
Paper Size/Weight/Type
Size
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTRR, and Custom Size (8 1/4" x 11" to 13" x 19 1/4" (210 x 279.4 mm to 330.2 x 487.7 mm))
Weight
16 lb bond to 140 lb index (60 to 256 g/m2)
Type*1
Thin (14 to 16 lb bond (52 to 63 g/m2)), Plain (17 to 28 lb bond (64 to 105 g/m2)), Heavy (29 lb bond to 140 lb index (106 to 256 g/m2)), Color, Recycled, Bond, Letterhead, and Coated*2
*1 80 lb cover to 140 lb index (210 to 256 g/m2) paper can be used only for one cover sheet.
*2 Coated paper can be loaded from the insertion unit only.
Maximum Number of Sheets You Can Trim
1/8" to 3/4" (2 mm to 20 mm)
40 sheets
Trimmer Booklet Waste Tray Capacity
Approximately 1,500 sheets of trimmed strip (width 3/4" (20 mm), 20 lb bond (80 g/m2))
13X7-0LX
