Staple Jams in the Stapler Unit (Staple Finisher-V1/Booklet Finisher-V1)
13X7-0KA
Follow the procedure described in this section to clear the staple jam. The Staple Finisher-V1/Booklet Finisher-V1 are optional. Optional Equipment
1
Open the front cover of the finisher.
2
Pull out the staple case from the stapler unit.
Hold the green tab of the staple case, and pull it out straight toward you.
3
Push up the bracket on the staple case.
4
Remove all the jammed and protruding staples from the staple case.
5
Return the bracket on the staple case to its original position.
6
Hold the green tab, and push the staple case back into the stapler unit until it is securely in place.
7
Close the front cover of the finisher.
imageRUNNER ADVANCE 8505i / 8595i / 8585i
User's Guide
USRMA-0034-012016-05Copyright CANON INC. 2016
