Feeder
13X7-0L9
Type
Printer separated, Stream feed (Feeder), No stream (Reader)
Original Feeding Mechanism
Automatic Document Feeder
Size and Weight of Originals
Size
11" x 17", LGL, LTR, LTRR, STMT, and STMTR
Weight
1-Sided Scanning (Black and White Original): 13 lb bond to 80 lb cover (50 to 220 g/m2)
1-Sided Scanning (Color Original): 17 lb bond to 80 lb cover (64 to 220 g/m2)
2-Sided Scanning (Black and White Original): 13 lb bond to 80 lb cover (50 to 220 g/m2)
2-Sided Scanning (Color Original): 17 lb bond to 80 lb cover (64 to 220 g/m2)
The combinations of document sizes that you can copy/scan*
Documents with the same width: A3 and A4, A4R and A5
* Copying/scanning with a combination other than described above may cause damage to the documents or paper jams.
Original Tray Capacity
300 sheets (20 lb bond (80 g/m2))
Original Scanning Speed
(LTR)
Copying (1-sided scanning)
120 sheets/minute (in Black-and-White at 600 x 600 dpi)
Copying (2-sided scanning)
75 sheets (150 pages)/minute (in Black-and-White at 600 x 600 dpi)
Scanning (1-sided scanning)*
120 sheets/minute (in Black-and-White at 300 x 300 dpi)
120 sheets/minute (in Full Color at 300 x 300 dpi)
60 sheets/minute (in Full Color at 600 x 600 dpi)
Scanning (2-sided scanning)*
120 sheets (240 pages)/minute (in Black-and-White at 300 x 300 dpi)
110 sheets (220 pages)/minute (in Full Color at 300 x 300 dpi)
30 sheets (60 pages)/minute (in Full Color at 600 x 600 dpi)
* The scanning speed may vary, depending on the scanning mode and original type.
imageRUNNER ADVANCE 8505i / 8595i / 8585i
User's Guide
USRMA-0034-012016-05Copyright CANON INC. 2016
