Booklet Finisher-X1
13X7-0LS
Paper Size/Weight/Type
Paper available for the Main Unit*
* You cannot staple transparencies, tracing paper, or labels.
You cannot saddle stitch and saddle fold pre-punched paper, transparencies, tracing paper, labels, or tab paper.
Capacity Per Tray
(Tray A)
No Collating/Collate/Group mode
LTR, EXEC, and STMTR: 1,500 sheets (or 7 3/4" (195 mm) in height)*
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, and LTRR: 750 sheets (3 7/8" (97 mm) in height)
Staple mode
One point at front (diagonal)/One point at back (diagonal)/Two points in center (parallel)
LTR and EXEC: 1,500 sheets/100 sets (or 7 3/4" (195 mm) in height)*
11" x 17", LGL, and LTRR: 750 sheets/50 sets (or 3 7/8" (97 mm) in height)
No Collating/Collate/Group mode with different paper sizes
750 sheets (or 3 7/8" (97 mm) in height)
Offset mode
LTR and EXEC: 1,500 sheets (or 7 3/4" (195 mm) in height)*
11" x 17", LGL, and LTRR: 750 sheets (or 3 7/8" (97 mm) in height)
Z-Fold mode (when the Paper Folding Unit-J1 is attached)
11" x 17": 30 sheets (or 7 3/4" (195 mm) in height)
LGL and LTRR: 10 sheets
Half Fold mode (when the Paper Folding Unit-J1 is attached)
LTRR: 10 sheets
* 750 sheets (or 3 7/8" (97 mm) in height) when the Thin paper or Custom Size paper (less than 15 lb bond (59 g/m2)) is used.
Capacity Per Tray
(Tray B)
LTR, EXEC, and STMTR: 250 sheets (or 1 1/4" (32 mm) in height)
11" x 17", LGL, and LTRR: 125 sheets (or 5/8" (16 mm) in height)
Paper with the length of 17" (432 mm) or more: 30 sheets
LGL, LTR, LTRR, EXEC, and STMTR: 125 sheets (or 5/8" (16 mm) in height)
11" x 17", LGL, and LTRR: 10 sheets
LTRR: 10 sheets
Capacity Per Tray
(Tray C)
No Collating/Collate/Group mode (Cascade-Load mode)
LTR: 2,500 sheets (or 12 3/4" (325 mm) in height)
No Collating/Collate/Group mode (Random-Load mode)
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, and LTRR: 750 sheets (or 3 7/8" (97 mm) in height)
Offset mode
Staple mode
LTRR:10 sheets
Max. Stapling Capacity/Available Staple Size
When the standard staple cartridge is attached
LTR and EXEC: 100 sheets (20 lb bond (80 g/m2)) or below 1/2" (11 mm) in height, 98 sheets (20 lb bond (80 g/m2)) + 2 sheets 140 lb index (256 g/m2))
11” x 17”, LGL, and LTRR: 50 sheets (20 lb bond (80 g/m2)) or below 1/4" (5.5 mm) in height, 48 sheets (20 lb bond (80 g/m2)) + 2 sheets 140 lb index (256 g/m2))
Max. Saddle Stitch Capacity/Available Saddle Stitch Size
Saddle Stitch
20 sheets (22 lb bond (81 g/m2)) (including 1 cover sheet up to 140 lb index (256 g/m2))
Saddle Folding
5 sheets (16 to 28 lb bond (60 to 105 g/m2))
Size
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTRR, and Custom Size (8 1/4" x 11" to 13" x 19 1/4" (210 x 279.4 mm to 330.2 x 487.7 mm))
Cover Weight
Requires the paper weight of the main document or more.
Power Source
100 - 240 V AC, 50/60 Hz, 2.8 A
Maximum Power Consumption
384 W (including the Puncher Unit and Inner Booklet Trimmer-A1)
Dimensions
(W x D x H)
30 1/4" x 30 1/8" x 41" (767 x 765 x 1,040 mm)
When the auxiliary tray is extended
35 1/4" x 30 1/8" x 41" (896 x 765 x 1,040 mm)
Weight
Approximately 242.5 lb (110 kg)
Installation Space Including the Main Unit
(W x D)*1
Without the upright control panel
79 1/4"*2 x 31 3/8" (2,014 x 798 mm)
With the upright control panel
93 3/4"*3 x 31 1/8"(2,382 x 789 mm)
*1 When the auxiliary tray is extended.
*2 When the right cover of the main unit is opened.
*3 To the right edge of the upright control panel in the rightmost position.
imageRUNNER ADVANCE 8505i / 8595i / 8585i
User's Guide
USRMA-0034-012016-05Copyright CANON INC. 2016
