Basic Copy Operations
This section describes the basic operations for copying.
1
Place the document. Placing Documents
2
Press <Copy> on the Main Menu. <Main Menu> Screen
3
Enter the number of copies using the numeric keys on the Copy Basic Features screen. Copy Basic Features Screen
4
Specify the copy settings as necessary.
Enlarging or Reducing Copies
Selecting Copy Paper
2-Sided Copying
Adjusting Image Quality of Copies
Confirm settings before copying
5
Press .
Copying starts.
To cancel copying, press <Cancel> or . Canceling Copies
Pressing  or  during copying enables you to adjust density.
When <Press the [Start] key to scan the next original.> is displayed
When multiple sheets are fed
Scanning is stopped and the message is displayed on the screen. Follow the message and start operation. To set to not notify with a message, press <Options> on the Copy Basic Features screen  <Detect Feeder Multi Sheet Fd.> to disable the setting each time you copy, or set <Set Detection of Feeder Multi. Sheet Feed as Default> to <Off> (<Scan Settings>  <Set Detection of Feeder Multi. Sheet Feed as Default><Common>).
TIPS
Reserving a copy
Even while the machine is being used for copying or stopped for clearing a paper jam, you can set and scan the next copy document. When the machine becomes available for use after finishing the previous operation, the next copy starts automatically. This function is called "Reserved copy." For example, to perform reserved copy while the printing or waiting screen is displayed, press <Close>, specify the copy settings in the usual manner, and press .
13X7-03J
