Upper tray
Upper cover
Front cover
Lower tray
Tray cover|
For information on the paper sizes that can be loaded into the Document Insertion Unit-N1, see Specifications.
If you are loading preprinted paper to use as the cover page into the document insertion unit, you must load the paper face up.
To load paper in the upper tray:
Adjust the slide guide.
To load paper in the lower tray:
Open the tray cover.
Open the packaging for the paper and remove the paper stack.
Fan the sheets several times and align the edges to facilitate feeding.
If you want to load paper into the upper tray:
Load the paper face up.
If you want to load paper into the lower tray:
Close the tray cover.
Make sure that the height of the paper stack does not exceed the loading limit mark (
You cannot make copies or print on paper that is loaded in the Document Insertion Unit-N1.
