Printing Job Hold Documents
1
Press <Hold> on the Main Menu.
<Main Menu> Screen
2
Select documents.
<Hold Job List>
The selection status of documents, icons indicating document types, as well as the document names and dates/times at which they were saved are displayed.
When a document is selected,
which indicates "selected" is displayed. When multiple documents are selected, the numbers in the center of
are displayed as 1, 2, 3 … in the order selected. When you press a selected document, the selection is canceled.
<Show Only Select'd Users>/<Display All Users>
Displays the documents of the selected user or all users.
<Details/Edit>
You can edit/check the job ticket of the selected document, check the printing contents, change the finishing setting, etc.
The job ticket is JDF (Job Definition Format) attribute information included in a document through the entire printing process. Some apply to the entire document and others apply to each page range divided by page. As for editing/checking the job ticket, you can confirm the steps one by one.
<Select All (Max 100)>/<Clear Selection>
If a document is not selected in
, <Select All (Max 100)> is displayed, which enables you to select all the documents in <Hold Job List>. When documents are selected, <Clear Selection> is displayed, and you can cancel the selection.
<Delete After Printing>
Deletes printed documents from <Hold Job List> automatically after printing.
<Start Printing>
Executes printing.
<Details/Edit>
You can choose for a selected document to be printed preferentially or see the details.
<Cancel>
Cancels printing.
<Print Job List>
Icons indicating the printing status of documents, the current status, and waiting time are displayed.
3
Set in accordance with the purpose.
Checking the printed material in the test print (Print Sample)
1
Press <Details/Edit>  <Print Sample>.
2
Set the number of copies and partition.
Depending on the document, the partition cannot be set.
3
Press <Start Printing>.
Printing starts.
4
Press <Close>.
Checking the contents of the document (Display Image)
1
Press <Details/Edit>  <Preview>.
Deleting a job
1
Press <Details/Edit>  <Delete>.
4
Printing starts.
If <Delete After Printing> is not selected, the document remains in the list even after it is printed.
