If you select <Copy>, you can set whether to consider the paper type.
If you set <Consider Paper Type> to <On>:
Paper is not fed from another paper source when the original paper source runs out of paper, unless another paper source is loaded with paper of the same size and type.
If you set <Consider Paper Type> to <Off>:
Paper is fed from another paper source when paper in the current paper source runs out, as long as the same paper size is loaded in that paper source.
If you select <Printer>, you can set whether to group paper sources.
If you set <Use Group> to <On>:
Paper sources are set as a group. When a specific paper source is selected in the printer driver, Auto Drawer Switching is performed in the group.
If you set <Use Group> to <Off>:
Paper sources are not set as a group. When a specific paper source is selected in the printer driver, Auto Drawer Switching is not performed.
