Saving Documents in Memory Media
Follow the procedures below to convert scanned documents into a file format commonly supported by a computer to save in memory media. This method is convenient when you need to move files to a computer not connected to a network.
1
Set the original.
Placing Documents
2
Press <Scan and Store> on the Main Menu.
<Main Menu> Screen
3
Press <Memory Media>.
4
Select the desired memory media.
5
Display the save location and press <Scan>.
6
Specify the scan settings as necessary.
7
Press
Originals are scanned and saved as files.
To cancel scanning, press <Cancel> or
<Yes>.
When <Press the [Start] key to scan the next original.> is displayed
Place the next original to scan and press
. After scanning all of the originals, press <Start Storing> to save the file.
To check the result of saving, press
<Store>
<Job Log>. If <NG> is displayed, the file is not saved successfully. Try the operation again.
