<Cc> or <Bcc>
<Specify Destinations> before specifying destinations.
<Remote>.
Destination type buttons
, and
displays e-mail, file server, and group destinations, respectively.
Drop-down list for selection of Address Book types
<Search by Name>
Search buttons by first letter
and enter the number for the desired one-touch button.
<LDAP Server>.
When searching by conditions
Search categories
Search conditions
Search characters
When searching by name
enter the text to search
press <OK>.
Scanned documents are converted into electronic files such as PDF. Select the file format according to your purposes and environment of use.
When creating files by pagesTo scan a multiple-page document as separate files by pages, not as a single file, press <Divide into Pages>
enter "1" press <OK>. If you select <JPEG>, a file for each page is created automatically. |
TIPS
Installing an option can expand functions for scanning to create files. System Options
To scan a document clearly, increase the resolution. To reduce the file size, decrease the resolution.
If you are scanning free size/highly transparent documents, or the edge of documents is missing when scanning, you need to manually specify the scanning size.
When scanning a free size document
When specifying the values of scanning size
When scanning a long document|
To register the scanning sizeIf you frequently specify the scanning size with the same values, register the size in <Custom>
<Register Size> to quickly recall the setting for convenience. |
You can specify color when scanning documents.
<Auto (Color/Gray)>
<Auto (Color/B&W)>
<Full Color>
<Black & White>
<Grayscale>
The machine can automatically scan both the front and back sides of a document.
Place the document in the feeder. For landscape-oriented documents, place them horizontally.
You can enlarge or reduce standard size documents to other standard sizes when scanning.
Enlarging or Reducing in Standard Paper Sizes
You can enlarge or reduce by specifying magnification (%).
Enlarging or Reducing by Specifying Magnification
You can enlarge or reduce to automatically fit the paper size selected.
Enlarging and Reducing to Fit the Finished Paper Size
<Copy Ratio>.
, to reduce, select magnification from
and press <OK>.
<Copy Ratio>.
<Copy Ratio>.
<Yes>.
When <Press the [Start] key to scan the next original.> is displayed
. When scanning all of the documents is complete, press <Start Sending> to send/save the file.
select a document
<Cancel>
<Yes>.|
To check the statuses for sent/saved documentsOn the <Status Monitor/Cancel> screen, you can check the statuses for sent/saved documents. This screen enables you to send/save documents again or cancel sending/saving after checking the statuses. Checking Status and Log for Scanned Documents
To print the report for the results of sending/savingOn the Scan Basic Features screen, pressing <Options>
<TX Report> enables you to set to automatically print the report listing the results of sending/saving.File nameWhen a file is sent/saved, its file name is automatically set based on the following format. You can change the setting so that a different name can be assigned. Setting a File Name
When sending by e-mail
"Job numbers (four digits)_page numbers (three digits).file extension name" format, such as "1042_001.jpg" When saving in a file server
"The year, month, day, hour, minute, and second the file is saved (14 digits).file extension name" format, such as "20151030133541.jpg" E-mail subjectThe subject entered in <Default Subject> is automatically set (<Default Subject>). If you specify a different subject, change the setting, or specify each time you send an e-mail (Specifying E-Mail Settings).
When multiple sheets are fedScanning is stopped and the message is displayed on the screen. Follow the message and start operation. To set to not notify with a message, press <Options> on the Scan Basic Features screen
<Detect Feeder Multi Sheet Fd.> each time you send/save a document to disable the setting, or set <Set Detection of Feeder Multi. Sheet Feed as Default> to <Off> (<Set Detection of Feeder Multi. Sheet Feed as Default>). |
TIPS
Determining the top and bottom of the documentYou can set the orientation of the document before scanning so that its top and bottom are positioned correctly when the sent/saved file is displayed on a computer.
When placing a LTR size original, press <Options> on the Scan Basic Features screen
<Original Content Orientation> <Top at Far Edge> <OK>.When placing large-sized originals such as LGL size, press <Options> on the Scan Basic Features screen
<Original Content Orientation> select <Top at Far Edge> or <Top at Side Edge> according to the orientation of the original press <OK>.Specifying multiple destinations including faxesSetting <Enable Fax in Scan and Send Function> to <On> enables you to specify fax destinations from the Scan Basic Features screen (<Display Fax Function>). This setting is useful for specifying multiple destinations including faxes, such as when saving a copy of a sent fax in a file server.
Checking scanned documents before sending/savingYou can check scanned documents on the preview screen before sending/saving. Checking Scanned Originals Before Sending/Saving (Preview)
Registering frequently used settingsYou can combine frequently used destinations and scan settings into a button of the machine for later use. By pressing the registered button when scanning documents, you can quickly complete your settings. Registering a Combination of Frequently Used Functions
