Connecting Directly (Access Point Mode)
1713-0J7
Even in an environment without a wireless LAN router, you can still directly connect your mobile device to the machine via "Access Point Mode," which enables connection between the device and the machine without the need to configure complicated settings, or by using Bluetooth LE or NFC for even simpler connection.
Optional products are required to use Bluetooth LE or NFC. System Options
Preparing to Connect Directly (Access Point Mode)
Establish a connection by using Access Point Mode in the following order.
Check the network settings of the machine.
Press   <Preferences>  <Network>  <TCP/IP Settings>  <IPv4 Settings>  set <Use IPv4> to <On>.
Prepare the mobile device.
Configure the mobile device to enable Wi-Fi connection.
Prepare the machine for connection.
Press   <Preferences>  <Network>  <Direct Connection Settings>  set <Use Direct Connection> to <On>.
Press   <Main Menu>  <Mobile Portal>  <Direct Connection>  <Enable>.
Connecting Directly
It may take some time for connection between the machine and the mobile device to be established.
Connecting Manually
1
With the machine as the connection destination, configure the wireless LAN settings on your mobile device, using the SSID and network key information shown on the touch panel display of the machine.
2
After completing the desired operations, press <Disable>.
Connecting with a QR Code
1
Start Canon PRINT Business on the mobile device.
2
Read the QR code shown on the touch panel display of the machine.
3
Connecting with Bluetooth LE (iOS)
1
Press   <Preferences>  <Network>  <Bluetooth Settings>  set <Use Bluetooth> to <On>.
2
3
Configure the mobile device to enable the use of Bluetooth settings.
4
Approach the machine with the mobile device.
The device name and PIN code are shown on the touch panel display. Using this information, perform pairing via the mobile device.
5
Connecting with NFC (Android)
1
Press   <Management Settings>  <Device Management>  set <Use NFC Card Emulation> to <On>.
2
If Canon PRINT Business has not been started when you touch the device to the machine, it will be started automatically.
3
Configure the mobile device to enable the use of NFC settings.
4
When touching an NFC compatible device to the machine, make sure that NFC compatible device is placed precisely on top of the NFC mark of the machine.
5
For details on using Canon PRINT Business, see the related manuals. (http://www.canon.com/gomp/)
For details on linking with mobile devices, see the Setup for Linking with Mobile Devices User's Guide.
TIPS
To check the connected mobile devices, press <Direct Connect. Info.> on the <Direct Connection> screen.
You can enable connection associated with login users by setting <Use Personal SSID and Network Key> to <On> in the <Access Point Mode Settings>. <Access Point Mode Settings>
While connecting via direct connection, you may not be able to connect to the Internet depending on the mobile device you are using.
If a wireless connection from a mobile device is not performed within 5 minutes while the SSID and network key are displayed, the status waiting for connection ends.
If the status without data transmission between a mobile device and the machine continues during communication by direct connection, the communication may end.
Power saving performance of sleep mode degrades while connecting via direct connection.
When you finish the desired operation, be sure to terminate the connection between the machine and the mobile device. If they remain connected, power saving performance of sleep mode degrades.
If you use the direct connection, do not set the IP address manually on the mobile device. Doing so may prevent proper communication after using the direct connection.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
