Staple Finisher-AA
1713-0SW
Paper Sizes
Max: 12 5/8" x 18" (320 x 457.2 mm)
Min: 3 7/8" x 5 1/2" (98 x 139.7 mm)
Paper Weight
14 lb bond to 110 lb cover (52 to 300 g/m²)
Paper Type
Paper available for the Main Unit
Capacity Per Tray*1
Upper Tray (Tray B)
No finishing set, Collate, Group mode:
LTR, STMT, STMTR, EXEC, A4, B5, A5, A5R: 250 sheets (or 1 7/8" (47 mm) in height)
11" x 17", 305 x 457 mm, LGL, LTR, A3, B4, A4R, B5R, 320 x 450 mm(SRA3): 125 sheets (or 1" (24 mm) in height)
With different paper sizes: 125 sheets (or 1" (24 mm) in height)*2
Collate + Offset, Group + Offset mode:
A4, B5, LTR, EXEC: 250 sheets (or 1 7/8" (47 mm) in height)
11" x 17", A3, B4: 125 sheets (or 1" (24 mm) in height)
Lower Tray (Tray A)
No finishing set, Collate, and Group mode:
LTR, STMT, STMTR, EXEC, A4, B5, A5, A5R: 3,000 sheets or height 16 5/8" (423 mm)*3
11" x 17", LGL, LTR, A3, B4, A4R, B5R, 320 x 450 mm(SRA3), 305 x 457 mm: 1,500 sheets (or 8 1/2" (216 mm) in height)
With different paper sizes: 1,500 sheets or height 8 1/2" (216 mm)*4
Collate + Offset and Group + Offset mode:
LTR, EXEC, A4, B5: 3,000 sheets or height 16 5/8" (423 mm)*3
11" x 17", LGL, LTRR, A3, B4, A4R: 1,500 sheets or height 8 1/2" (216 mm)
Staple (Corner/Double):
LTR, EXEC, A4, B5: 200 sets/total 3,000 sheets (or 16 5/8" (423 mm) in height)
11" x 17", LGL, LTRR, A3, B4, A4R: 100 sets/total 1,500 sheets (or 8 1/2" (216 mm) in height)
Staple (Staple-Free):
LTR, A4: 200 sets
A3, B4, 11" x 17": 100 sets
Booklet Tray
25 sets (14 to 28 lb bond (52 to 105 g/m²), up to 5 sheets)
15 sets (14 to 28 lb bond (52 to 105 g/m²), 6 to 10 sheets)
10 sets (Other)
Staple
Max. Stapling Capacity*5
LTR, EXEC, A4, B5, and 16K:
50 sheets (14 to 24 lb bond (52 to 90 g/m2))
30 sheets (25 to 28 lb bond (91 to 105 g/m2))
2 sheets (29 bond to 140 lb index (106 to 256 g/m2))
11" x 17", LGL, LTRR, A3, B4, A4R, and 8K:
30 sheets (14 to 24 lb bond (52 to 90 g/m2))
20 sheets (25 to 28 lb bond (91 to 105 g/m2))
2 sheets (29 lb bond to 140 lb index (106 to 256 g/m2))
11" x 17", LTR, A3, A4, and 16K:
5 sheets (14 to 17 lb bond (52 to 64 g/m2))
4 sheets (17.3 to 21.7 lb bond (65 to 81.4 g/m2))
3 sheets (21.7 to 28 lb bond (81.5 to 105 g/m2))
Manual Staple:
All sizes: 50 sheets (24 lb bond (90 g/m2))
Punch
(When the puncher unit is attached)
Paper Sizes
Two/Three Holes:
Two Holes: 11" x 17", LGL, LTR, LTRR, EXEC, A3, B4, A4, A4R, B5, B5R, 8K, 16K, and 16KR
Three Holes: 11" x 17", LTR, EXEC, A3, B4, A4, B5, 8K, and 16K
Paper Weight
14 lb bond to 110 lb cover (52 to 300 g/m2)
Punch Hole
Two/Three Holes
Dimensions (W x D x H)
21 1/8" x 24 1/2" x 38 1/8" (537 x 623 x 969 mm)
Weight
Approximately 66.1 lb (30 kg)
Installation Space Including the Main Unit
(W x D)
63 3/4" x 44 1/4" (1,620 x 1,123 mm) (when the auxiliary tray is extended)
*1 For 21.7 lb bond (81.4 g/m²) paper only. Capacity varies in other cases.
*2 Only with LTR, A4, and B5: 250 sheets (or 1 7/8" (47 mm) in height)
*3 Thin (14 to 15 lb bond (52 to 59 g/m²)): 1,500 sheets (or 8 1/2" (216 mm) in height)
*4 Only with LTR, A4, and B5: 3,000 sheets (or 16 5/8" (423 mm) in height)
*5 When the standard staple cartridge is attached. (The maximum stapling capacity may vary, depending on the paper type and weight.)
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
