<Maintenance>
1713-040
This section describes how to use the auto cleaning function for the main unit and feeder.
<Clean Inside Main Unit>
  <Adjustment/Maintenance>  <Maintenance>
If streaks appear on printed paper or part of the image is missing, execute <Clean Inside Main Unit>. Cleaning the Interior
<Clean Feeder>
If streaks appear on originals scanned with the feeder or paper that is printed, execute <Clean Feeder>. Cleaning the Feeder
<Original Scanning Area Cleaning Method>
Start the video that shows how to clean the platen glass.
<Replace Toner Cartridge>
  <Adjustment/Maintenance>  <Maintenance>  <Check Maintenance Method for Consumables>
Plays the sample video explaining the method for replacing toner cartridges. You can play this sample video even when replacement is not necessary, so that you may understand the process in advance.
<Replace Waste Toner Container>
Plays the sample video explaining the method for replacing the waste toner container. You can play this sample video even when replacement is not necessary, so that you may understand the process in advance.
<Load Staples (Staples)>
Plays the sample video explaining the method for loading staples. You can play this sample video even when replacement is not necessary, so that you may understand the process in advance.
<Load Staples (Saddle Staples)>
Plays the sample video explaining the method for loading saddle stitch staples. You can play this sample video even when replacement is not necessary, so that you may understand the process in advance.
<Replace Drum Unit>
Plays the sample video explaining the method for replacing drum units. You can play this sample video even when replacement is not necessary, so that you may understand the process in advance.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
