Clearing Paper Jams
1713-06R
If a paper jam occurs, a message, the location of the paper jam, and the procedure for clearing it are displayed on the screen. If you do not know how to clear the paper jam from viewing the screen, see Paper Jam Locations to clear the paper jam. For information on cautions when clearing paper jams, see "Important Safety Instructions" in the FAQ Guide and Optional Equipment.
Cautions When Clearing Paper Jams
If Paper Jams Frequently Occur
Paper Jam Locations
For information on the paper jam locations and the method for clearing paper jams, see the following diagram and references.
Inside the main unit Paper Jams in the Main Unit
Paper may not actually be jammed in the location you check. Even in this case, follow the instructions on the screen to check all the locations.
The screen indicating that there is a paper jam is repeatedly displayed until you clear the paper jam.
If you press <Close> on the screen indicating that there is a paper jam, you may be able to continue to perform operations and specify settings without immediately removing the paper jam.
Do not remove paper from a location other than that displayed as a paper jam location on the screen. This may cause paper jams in other locations or missing pages in output documents.
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
