By combining options, you can use functions more efficiently.
When the Staple Finisher-AA/Booklet Finisher-AA is installed
Booklet Finisher-AA
You can perform collating, grouping, stapling (Corner/Double/Saddle Stitch), and saddle folding with this option. In addition, you can manually bind with the stapler or bind without the stapler. Staple Finisher-AA/Booklet Finisher-AA/2/3 Hole Puncher Unit-A
Cassette Feeding Unit-AP
Load the type of paper that you frequently use. You can load paper that cannot be loaded in the paper drawer 1, such as A3 and custom size paper. Cassette Feeding Unit-AP
You can perform collating, grouping, and stapling (Corner/Double) with this option. In addition, you can manually bind with the stapler or bind without the stapler. Inner Finisher-K
When Other Options are Installed
Inner 2way Tray-J
This option enables paper to be output to two locations. If you have installed the Copy Tray-J, paper can be output to three locations. Inner 2way Tray-J
Copy Card Reader
You can implement Department ID Management using the card reader. Copy Card Reader
Copy Tray-J
Install this to use finishing modes such as Collate, Group, and Rotate 90 Degrees. Copy Tray-J
Inner Shift Sorter-A
Install this to use finishing modes such as Offset and Collate. Inner Shift Sorter-A
Utility Tray-B
This option provides space for placing originals.
For information on the combination of options that can be installed on the machine, contact your local authorized Canon dealer.
