Adjust the settings below if printing results are not satisfactory, or if you want to adjust the paper folding position.
Gradation Adjustment
If color gradation reproducibility has become so poor that the printed gradation differs markedly from the print data, make adjustments to improve color gradation reproducibility.
If the density of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
If the colors of printing run or blur, color mismatch (color misregistration) may have occurred. The problem may be improved by performing color mismatch correction.
If the size of the image copied is slightly different from the original, fine adjustment is performed so that the printed size more closely matches the size of the original.
