If this setting is set to <On>, you can change network settings. If errors related to network connections occur, an error message appears on the touch panel display of the machine. Canceling the Network Setting Lock
Specify whether to perform the automatic update when the mapping between the host name and IP address is changed on an environment such as DHCP. Making DNS Settings
Specify settings for using the DNS function on a system that does not have a DNS server. Making DNS Settings
<Computer Name/Workgroup Name Settings>
<Preferences> <Network> <TCP/IP Settings>
Specify the name of the machine on the network and the name of the workgroup it belongs to. If your environment does not have workgroups, create a workgroup in Windows and enter the name of that workgroup.
<SMB Server Settings>
Specify the SMB server settings to open the Advanced Box to the public in a network. Making SMB Settings
<SMB Client Timeout>
Specify the time to wait for a response from the SMB connection destination when the machine attempts a network connection as an SMB client.
When sending to an SMB server, the network connection was lost or the response on the server side was slow, causing a wait time timeout on the machine side before the data could be sent or forwarding could be completed.
If this happens, you may be able to avoid a timeout by increasing the wait time.
Specify settings for LPD printing. To use LPD printing, press <On> and set the time until the job is automatically canceled when the print data cannot be received due to a communication error, etc.
Banner pages are set to be output by print job. Even if <LPD Banner Page> is set to <On>, banner pages are not output for print jobs that are set to not output a banner page.
<RAW Print Settings>
Specify settings for RAW printing. To use RAW printing, press <On> and set whether to use bidirectional communication and the time until the job is automatically canceled when the print data cannot be received due to a communication error, etc.
Specify settings for FTP printing. To use FTP printing, press <On>, and set <User Name> and <Password> as necessary.
<Use UTF-8 to Display Name of FTP Print Job>
Specify whether to use UTF-8 for displaying file names when you perform FTP print.
<WSD Settings>
Specify the WSD settings. To use WSD (Web Service on Devices) for the print application, set <Use WSD> to <On>. To use WSD to retrieve the information for the machine, set <Use WSD Browsing> to <On>.
To use the WSD Scan function, set <Use WSD Scan Function> to <On>. Using WSD
If you set <Use WSD> to <On>, <Use WSD Browsing> and <Use HTTP> are also set to <On>.
If you set <Use WSD Scan Function> to <On>, <Use HTTP> is also set to <On>.
Specify settings for IPP printing. To use IPP printing, press <On> and set whether to encrypt the IPP communication data with TLS and whether to use IPP authentication.
If you set this to <On>, <Use HTTP> is also set to <On>.
To use the IPP authentication function by setting <Use Authentication> to <On>, the user information of the machine is used as the user and password for IPP authentication. Make sure to register the user information in advance when using the IPP authentication function. Registering User Information in the Local Device
Specify settings for multicast sending of the Sleep mode notifications on the network.
This setting can only be specified from the Remote UI.
<Use HTTP>
Enable or disable HTTP setting.
By specifying this setting as <On>, you can open a necessary port. However, it is recommended that you specify it as <Off>, if a port is not used. If you leave the port open, an unauthorized user may access the machine.
If you set this to <Off>, the following settings are also set to <Off>.
<Remote UI>
<IPP Print Settings>
<Use WSD Scan Function> and <Use WSD> in <WSD Settings>
Specify whether the host resources MIB is compliant with the specifications of RFC2790.
<Dedicated Port Settings>
Specify whether to configure/refer to detailed information of the machine from the Canon drivers or utility software.
If the setting is set to <Off>, some application that uses dedicated port may not be used.
<Dedicated Port Authentication Method>
Specify the authentication method for the dedicated port.
If the setting is set to <Mode 2>, communication using a dedicated port uses a secure mode. Accordingly, you may not be able to connect from device management software or drivers, etc.
<Use Spool Function>
Specify whether to spool print jobs that are sent to the machine in the hard disk of the machine.
Specify whether to set the machine to the power save mode periodically, according to the signals sent by a wireless LAN router. Connecting to a Wireless LAN
Specify the time before communication is automatically terminated when there is a prolonged period of no data transmission/reception while communicating using direct connection (access point mode).
When <Use Personal SSID and Network Key> is set to <On>
Information on the user and SSID/network key when logging in is associated and stored in the machine. Only one mobile device can be connected at a time.
When <Use Personal SSID and Network Key> is set to <Off>
If both <Specify SSID to Use> and <Specify Network Key to Use> are set to <On>, multiple mobile devices can be connected at the same time. A maximum of five devices can be connected at the same time.
If either or both <Specify SSID to Use> and <Specify Network Key to Use> are set to <Off>, a random SSID or network key is used to connect each time. Only one mobile device can be connected at a time.
