Receiving I-Faxes
1713-0EF
When an I-fax is received
The Processing/Data indicator on the control panel blinks green. When receiving is complete, the document is automatically printed and the indicator turns off.
To cancel receiving, press   <Receive>  <Job Status>  select a document  <Cancel>.
You can specify the time before reception is canceled when receiving a divided I-fax and the subsequent data cannot be received. Data received by the specified time is printed. <Divided Data RX Timeout>
Output paper
An incoming I-fax is printed on the same size of paper as the document size received. When there is no paper matching the size of the received document, the document is printed according to the setting of <Select Drawer>. <Select Drawer>
To receive I-faxes manually
Press   <Receive>  <Job Log>  <Check I-Fax RX>. On the Main Menu (<Main Menu> Screen), pressing <Fax/I-Fax Inbox>  <Memory RX Inbox>  <Divided Data RX Inbox> enables you to check the receiving statuses of I-faxes divided and their data size.
TIPS
You can save paper when printing.
You can include information, such as reception time, in received documents when printing. <Print RX Page Footer>
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
