Removable HDD Kit
1713-092
The "Removable HDD Kit" is a hard disk holder with which you can remove the hard disk in the machine. Remove and store the hard disk in a safe place to protect your data.
Hard disk holder
Holds the hard disk and attaches to the machine. To store the hard disk, remove this hard disk holder.
A lock is not included with the "Removable HDD Kit." Purchase a lock that is commercially available for security.
Do not attach/remove the hard disk holder while the operation of the main unit continues. Doing so may damage the hard disk holder.
When attaching/removing the hard disk holder, be sure to first discharge static electricity from your body. Also be sure not to touch the connector.
A hard disk is fragile equipment. Note that Canon will not be liable for any damages resulting from the loss of data on the hard disk drive.
If the <E602-0001> message appears on the touch panel display when the machine starts, a hard disk may not be set in the hard disk holder. Turn OFF the machine and check that the main power indicator on the control panel is not lit, and then check whether the hard disk is set. If the error message still appears even though a hard disk is set, contact your local authorized Canon dealer.
Setting/Removing the Hard Disk Holder
Setting the hard disk holder
imageRUNNER ADVANCE C3530i / C3525i
User's Guide
USRMA-1814-002017-02Copyright CANON INC. 2017
